DerrickM
- Billings, Montana, USA
I am installing a pole mount system with an 8" sch 80 steel pipe buried in the ground approx. 8'.
The electrician I am working with has installed many street lighting poles and bases and recommended we install a ufer ground, attached it to the rebar structure deep in the concrete base and bring it up to the top of the base for future attachment.
Now microinverters no longer need a GEC, so the EGC in its cable is all you need in your branch circuit wiring and for bonding the circuit and the rails/ frames of your solar equipment.
I watched Mike Holts presentation on Auxilary grounding electrodes and how much he feels they add to the risk of lightning attacking your solar electronics etc. I'm thinking based on that, I do not want to connect that ground wire coming out of the earth to my microinverter branch circuit EGC because of this risk.
Why did we install the ground wire in the earth if we are not going to be using it or if it can cause serious damage from a possible lightning strike in the nearby earth?
Any thoughts?
Thanks,
Derrick
Any thoughts?
Thanks,
Derrick
