solarken
NABCEP PVIP
- Hudson, OH, USA
- Solar Design and Installation Professional
I am designing a 72kW PV system for a farm. The service is 480V 3ph at a pole that is in the middle of three grain silos. There are several service feeds coming off the pole, and some via taps just before entering the weatherheads. There is an empty 2-inch conduit at the base of the pole that comes up just outside the building I am installing the array on. The conduit run is about 120ft. There is a 240V single phase loadcenter in the building that is fed from a transformer in a small electrical buidling about 20ft from the pole, but it is too small to land the inverter output on and would also require too many single phase inverters tom be installed. Instead, I am am planning on a 480V-3ph line side connection using a SquareD H363-NRB as the system disconnect, and mounting it either at the building side of the conduit, or the pole side of the conduit. I will have the electrician who routinely deals with changes at the pole service tap and extend the 480V to the disconnect. Questions I have:
Should I mount the disconnect near the building or near the pole?
Where do I need to drive a ground rod and how many, for either option?
I assume I will need to bond the neutral to ground in the disconnect only, and run the neutral and ground separately from the inverter to the disconnect. Is that correct?
I appreciate any advice you can give!
- Ken
- Ken
