Announcement
Collapse
No announcement yet.
24vdc and rs-485 in same condiut
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Hello, Everyone!
    We have a customer that is running 24vdc and RS-485 communications lines in the same conduit for a solar PV monitoring application. The questions is wheather the 24vdc needs to be grounded in this application? I have searched quite a bit and can't seem to find any best practices published on this topic. Does anyone have any thoughts on this? Much appreciated!!
    Sean
    #2
    Originally posted by seand27 View Post
    Hello, Everyone!
    Sean
    is the 24VDC a class 2 circuit?
    Bob
    Comment
      #3
      Hi, Bob.
      Thank you so much for posting a response so quickly. Honestly, I am not sure if it is a Class 2 circuit or not, but I will try and confirm that. The device generating the 24vdc in this case is this Weidmuller power supply:
      https://catalog.weidmueller.com/cata...tID=8739140000
      If this is a class 2 circuit, should the 24VDC be grounded?
      Cheers!
      Sean
      Comment
        #4
        Hi, Bob.
        Cheers!
        Sean
        The power supply label that you linked to shows it is a listed class 2 power supply so it probably is a class 2 circuit. And equipment grounding conductor is not likely required. I am not real sure if you are asking if an equipment grounding conductor is required or if one leg needs to be grounded.
        Bob
        Comment
          #5
          Great. Thanks Bob.
          So, just so I am clear, does that mean we do not need to ground the 24VDC?
          Thanks!
          Sean
          Comment
            #6
            There is no requirement in the NEC to ground one of the legs of the power supply output circuit. 250.162 covers if a DC system needed to be a grounded system, and you system is not required to be a grounded system.
            Don, Illinois
            (All code citations are 2017 unless otherwise noted)
            Comment
            Working...
            X
