Gas Piping Clearance
SunFish
NABCEP Certified
ID
Sr. PV Systems Design Engineer
I know about the 3' clearance rule for electrical equipment in proximity to gas meters & pressure regulators. Is there any clearance requirements for gas pipe from electrical equipment such as inverters & breaker panels?
ggunn
Austin, TX, USA
Electrical Engineer - Photovoltaic Systems
Not in any jurisdiction I work in, but the rules are not consistent. Some say three feet from the pressure relief valve, some say four, some say measured radially, some say linearly. Check with the governing AHJ.
jaggedben
Northern California
I've seen restrictions issued by a utility (PG&E) but it was only with respect to the riser on the utility side of the meter, not gas pipe in general.
pv_n00b
CA, USA
Watch out for the general electrical equipment working area requirements. I have seen people mount equipment above or below gas pipes that are running horizontally along a wall.
