burtonboarder84
I am using PV inverters that require a neutral. They are mounted on an out-building not attached to biulding where the main service is. I am installing a sub-panel for the inverters. I need to run a neutral to the sub-panel right? I know since the building is not attached I need to bond the sub-panel. But my question is I NEED to run a neutral right?
