Announcement
Collapse
No announcement yet.
2020 Nec-- Equipment Grounding Conductor & Box Fill
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    This one my cause some issues with conductor fill in multi gang boxes
    314.16(B)(5) Equipment Grounding Conductor Fill.
    Where up to four equipment grounding conductors or equipment bonding jumpers enter a box, a single volume allowance in accordance with Table 314.16(B) shall be made based on the largest equipment grounding conductor or equipment bonding jumper entering the box. A 1∕ 4 volume allowance shall be made for each additional equipment grounding conductor or equipment bonding jumper that enters the box, based on the largest equipment grounding conductor or equipment bonding conductor.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
    #2
    Thats a change that will be missed by many... and will require all the box fill test questions to be rewritten!
    Moderator-Washington State
    Ancora Imparo
    Comment
      #3
      Not a good idea
      ~RJ~
      Comment
        #4
        Are we the point where people just need to come up with ridiculous code changes and the CMP accepts them with little or no substaniation? Really, more than 4 each counts as 1/4, this is starting to sound like a joke.
        Rob
        All responses based on the 2017 NEC unless otherwise noted
        Comment
          #5
          Yes, we are. It's a steady decline. I mean it when I say we need to go to a ten year code cycle.
          If Billy Idol is on your playlist go reevaluate your life.
          Comment
            #6
            The constant micro-tweaking is very annoying, more often than not unsubstantiated, and not in line with the real purpose of the NEC which is safety.
            Rob
            Comment
              #7
              It does appear to be bordering on the insane.
              Comment
                #8
                That's the general course that the NEC is taking. What happened to these CMP's?
                Rob
                Comment
                  #9
                  They are well meaning I'm sure, but there is just not enough real problems out there any more so we are left with these nick picky changes because there is nothing left to act on.
                  Comment
                    #10
                    Where is the documented hazard?
                    Comment
                    Working...
                    X
