TOOL_5150
- bay area, ca
Well, if you insist--- You're a hack...Oh yeah- Happy new year
~Matt
The same generation of wire also produced 10/3 nm without ground. I have also seen and used 8/3 without ground that had a plastic jacket not cloth. I may even still have some in the basement. :smile:
That generation must still be around. Every new house I do has some 12/2 w/o ground in it.
Yep for central vac systems.... 14/2 also.....
How does this apply to your work?
When I read the OP question I thought he was refering to the ground. I didn't think it was o.k. not to have it in 2002 but I can't remember. How many places are 6 years behind on code updates?
Isn't odd, how we most often say X/2 or X/3 and assume the ground, like with NM or MC, but we know to add a conductor with cables like SO or SJ?
Yes.![]()
"Have you ever seen 6/3 without a ground"?
Me too, about a month ago.
Without paying attention, I bought the wire and snaked it under a house.
When i got ready to make up the receptacle, I stripped off the outer covering and guess what....No grounding conductor.
A little lack of attention cost me about 4 hours.
steve
The op never clarified if he meant 6/3 with ground or without. I think that is what he meant but am not certain. He may have been referring to the use of nm instead of se cable.
Hmmm, 2002 NEC wiring with romex, not sure why were asking about an EGC in the cable. IMO the question is based on the ampacity of NM. If the original poster comes back we might find out what his real question is. :wink:
The real question: How does an Electrical Engineer that designs aircraft electrical power systems install a 50A circuit for a new electric range? :grin:
Correct. In an existing installation, the branch-circuit wiring determines everything else: the receptacle and the cordset. And, one must be diligent about connecting or removing the appliance's bonding jumper as necessary (after finding it.)I know its an old post but I'm cleaning up my email. Correct me if I'm wrong, and I'm sure someone will, but it is perfectly legal to make up range cords (not branch circuits) with 6-3 to match existing 3 wire range circuits.
Ranges run on 400 Hz, don't they?The real question: How does an Electrical Engineer that designs aircraft electrical power systems install a 50A circuit for a new electric range? :grin:
