What's the ballpark price on those?
Does it work with conductors in conduit?
Progressive (Now Tempo) Electronics 2003 fault locator.
Every time I've used it, it gets me down to 1" of the actual fault.
You aren't trying real hard then.
The few times I have had to locate a break in a conduit, the PVC just happened to be damaged in the area of the fault. Even a slight crack will let enough moisture in/out to allow a locate.
A TDR will work but that takes even more money.
I agree, 250' isn't worth the time for a repair. Out with the old & in with the new. Take note of what the damaged UF looks like and ask if someone planted a new tree or post in the last year or two.
Not arguing at all. I think they will get closer than 1" if you try real hard and the insulation break is small.
That's right SLACKER.A spot the size of quarter is too big?
