- Massachusetts
ELA, it is my understanding that the internal parts of the same grade and brand of 15 and 20 amp receptacles are identical. Only the face is different.
I've more than once picked up a brand new GFI put it in and it doesn't act like it should. They can be finnicky sometimes.
That's the price we pay for mass production.
No I am not concerned with my wiring. I have a GFCI breaker feeding the bath circuits.If you're concerned about your wiring, install a 20a bath circuit and use a GFI breaker and a commercial-grade receptacle.
true. only pressure plated connections are possible on 12 wire, but only Tony knows if this gfi was on a 20A circuit or a 15A circuit. 14 years ago, bath gfi's were not required to be on a 20A circuit.
It's also only an inch or so in length.The Leviton brass or other alloy leaf spring that supports the silver contact is 0.012" x 0.130" or 0.00156 sq-in. This is between the cross sectional area of #17 and #18 and it is not copper so the resistivity is somewhat greater. However, it is sort of in free air.
