RayS
- Cincinnati
Question was, if 2 of 4 flourescent lamps are removed, do you save 50% of lamp wattage, or more, or less? I said more than 50%, because of ballast losses, and have read that cooler operation helps efficiency.
I tried 1 fixture, removing the outer lamps actually increased current draw- about 40% as I recall. Removing inner 2 lamps did reduce current 56%. I am at a loss to explain this.
Why would it increase removing the outer lamps?
Why would it be different for the inner lamps?
notes: 4 Tube t8 fixture, sylvania ballast, true RMS clamp on meter
