formula for tons
Here's another place to look - scroll down to "power"
http://www.onlineconversion.com/
If you're trying to get a ballpark number for estimating a circuit for an air-handler, ok. If you're trying to size an air-handler, check with a Mechanical Engineer - there's a lot more than just KW.
You can use that website to find out how many nits in a Footlambert, too.
db
db
A Nit (Louse Egg) is a smooth, oval shaped structure which is attached to the side of the hair shaft ranging in color from off-white to brown and is slightly smaller than a sesame seed. ??????
