Hello all,
We recently we contracted to replace bulbs and ballast in metal halide pole lights at a peak power natural gas power plant. Some of these fixtures are about 20 ft from a 500,000 volt primary line. These fixtures are discharging static electricity when our tech changed the bulb thru gloves rated for 17500 volts. Our tech stated that if he put a pair of pliers near the light it would arc a large static dischard countinuosly and increasing in intensity as he got the pliers closer to the light. These poles have ground rods installed at the base of them and the bottom of the pole is bonded. Our Tech also tried installing a temporay #10 ground wire directly from the ground rod to the light but when he got the wire close to the light fixture it shocked him enough that he gave up on that idea. As he moved his hand (with gloves on) close to the light he could feel a vibration and as he was about to touch the light its shocked him. After he made contact with the light it no longer shocked him. Any Ideas on how we might resolve this issue where these fixtures can be maintained safely?
Thanks in advance,
Alan Helton
Thanks in advance,
Alan Helton
