goldstar
 - New Jersey
 - Electrical Contractor
Does this happen in other parts of the country or just here in NJ
   :grin:
	Classy .....
Usually around here they just pry them off and let them hang.
I know of ONE siding contractor in my area that actually calls the POCO to float the meter can for him and then re-attach it when he's done.
I've never heard of that. Which POCO would actually do this? In my experience most POCO's don't get involved past the weatherhead.
Not sure what type of siding was underneath the vinyl but if you look at the w/p SER connector and realize that there just isn't that much play behind it, with respect to the meter can, then allow for the foam insulation that is tacked on the side before the vinyl goes on I would say that the can is not recessed into the original siding. But, obviously it's recessed into this siding job.growler said:I think the meter can in the picture is recessed into the wall somewhat. I'm not sure why they did it this way but it would have been difficult to pry off.
For those siding contractors who "know what they're doing", "have done this many times before" and "are brave" this might be the case. But you know as well as I that doing so without removing the cover, pulling the meter and pulling out the mounting screws is more dangerous that one would think.Yes, they would normally just pry them loose and let them hang in this area.
You will see the same mistakes all over the country because the sidding crews are just as likely to be from New York or California as to be local guys.
I have heard that if a building permit is issued for vinyl siding in MA then an electrical permit must be issued because of this situation.
I am not sure if this is a MA requirement or just some towns, but it is a good idea
It is a MA requirement for sure. most towns will not issue the siding permit until the elec is issued.
Tom
Sure would like to see something in writing saying they can do that.
