slick 50
- 6 super bowl ring city
Welding cable is so easy to work with but you cant use it as feeders
. Is there any specific reasons not to use this cable for other than secondary conductors per 630.41
Welding cable is so easy to work with but you cant use it as feeders. Is there any specific reasons not to use this cable for other than secondary conductors per 630.41
Welding cable is great stuff when you need it. Find some that has a rating you can use. A lot of it is dual rated....
http://www.generalcable.com/NR/rdon...-E527283DB631/0/P_032_SVT_WeldingCablepdf.pdf
check this out 1/0-4/0 also rated RHH/RHW
