Hi All
I have a manufactured mechanical room that includes supply fans, return fans, outside air fans, circulator pumps, lights, receptacles, ddc panel and freeze protection heaters.
The unit will be provided with variable frequency drives for the motors, each with line and load side switches.
All of the elements will be field wired - the assembly will come with conduits to a junction box.
Note that there is no compressors within the unit.
I believe this is a Motor Operated Appliance per 422.11 (G) as supplemented by 430 with 422 taking precedence if 430 is less strict.
And, I currently do NOT beleive this is a ROOM as identified by the IBC, specifically as the Architect will not certify the assembly as a room relative to projects buidling classifications.
I also believe that I need to disconnect the assembly prior to anyone openning the door.
Yet, I can not find any specific statement supporting my belief.
All thoughts are appreciated.
Best Regards
RobT
Best Regards
RobT
