Paint booth exhaust stack lighting protection
Davebones
Installing a paint booth near Tampa Fl . ( lighting capitol ) The exhaust stack will be 3' wide by 11' high .Wondering about lighting protection if required. Any suggestions would be appreciated ....
Look up NFPA 780.
The dimensions of the stack are not important, however the entire structure's elevation profile is. The general concept of the Franklin method of LP is providing a lightning attractor highpoint over the protected area. Metals more 'attractive' than non-conductive materials. So if your stack would be fiberglass and you install an independent lightning mast away and above, you are forming a protective zone over the stack. Flashover is still possible, but the better your grounding is the less likely that would be.
