I have a chandelier that weighs over 125 lbs. and was supplied with a light-weight chain with open (non welded) links 1/8" in diameter. I know that over time, the metal will migrate due to gravitational forces and the fixture will fall to the floor. The manufacture claims this will not happen, and refuses to supply a heavier gague chain that has solid (welded) links unless I can prove my case.
I have searched on this site, and the NEC however, I am unable to find anything relative to this issue. Can somebody please help me find a code referance or other supporing documentation. My job is subject to the rules of the 2005 NEC. The only thing I was able to find is Article 410.36 which states:
Design & Material
Luminaires.......shall be designed and assembled so as to secure reqisite mechanical strength and rigidity.
Is there something that specifically requires welded or solid links for fixtures over a certain weight?
Design & Material
