Leakage current related
anbm
TX
Designer
Is there a standard/code item on limitation of max. leakage current allowed for any electrical devices or max. load can put in an isolation panel to avoid leakage current?
How to check / measure leakage current? Thanks!
Is this in a hospital, data center, commercial establishment?
One place to measure any ground current is at the neutral ground bond.
Can you describe what you mean by leakage current?
