It is time to replace and upgrade the cordless drills. I have mostly old Dewalt. They are tough, but batteries are old. With what new batteries cost, I just as well buy new drill kits!! I know this has been mentioned many times here before, but do you have any tips on the latest in Lithium batts, size etc. ? Thanks to all for making this forum GREAT!:smile:
I'd first ask a few questions.
What do you drill most? Wood? Masonry?
If wood, what size and type of bit?
If masonry, how much?
Do you need hammer function?
Do you use it for driving screws?
Drills that can handle the kind of drilling I do in wood (16"x7/8" auger bit, 6"x1-1/4" auger bit, often in old wood and/or hardwood beams) are going to be harder to find and are usually bigger and costlier. You can drill those sizes with spade bits and a weaker drill if you don't mind keeping a lot of spare bits around. You'll also want big batteries. Forger the slim Li-Ion ones, they don't have the capacity.
For masonry, a lighter drill should work, but I'd recommend testing some if you can. I found my Milwaukees were great at masonry drilling, not sure why. If you drill a lot, again go for a bigger battery since the slim ones will crap out a lot sooner.
If you set screws with it, TEST the clutch function. Two years ago I bought a Fein 18V hammer drill (discontinued, unfortunately) that is a real beast in wood (my Johnson's bigger than your Johnson
), but the clutch is worthless. On the lowest settings you can strip out or twist the heads off of most screws up to #10.
On my radar now are:
Milwaukee M18 with large Li-Ion pack (62nm-550 in./lbs)
http://www.milwaukeetool.com/Produc...=2602-22&CategoryName=New+Products+and+Offers
The Metabo SB 18LTX (100nm-885 in./lbs)
http://www.metabo-cordless.com/Cordless-Drill-Drivers-LTX-Class.27269.0.html
Hilti UH 240-A 24V (85nm-752 in./lbs)
https://www.us.hilti.com/holus/modules/prcat/prca_product.jsp?OID=30891&CATE_OID=-17635
The Metabo outbeasts the others with torque by specs. I should have a chance to check one out in the next week or so and possibly test it some. I've seen the Hilti and it's big - really big. Not the drill you want if you're doing overhead stuff all the time, but maybe the right one for wood intensive work. I should also have a chance to view the Milwaukee soon. Man, I could really get into being a tool tester
