Google (image) is your friend!
Here is an over view of most the the "Shunt"'s available. I beleive an elevator shunt is a dual element with remote shutdown. the remote is controled via a Fire alarm IE it breaks the voltage coil, or the sensing coil (F/A)
releases the current sensing coil...
in the past 30 or 40 years elevators have incorporated devices intended to try to keep people from being cooked alive in the event of a fire. in a modern elevator, once a fa is in alarm, power is shut off (usually via a shunt trip mechanism) and the elevator is sent to a place where passengers can hopefully disembark safely, and only the fireman can use the elevator.
someone should explain this to engineers...we are currently doing a walgreens (fun if you've never tried one)....the engineers spec'd a 125A 3PH GFCI for the elevator...shunt trip...GFCI....220.....221.....whatever it takes
