zog
- Charlotte, NC
I know it takes a bunch of energy to "start" a flourecent light, is it better to leave them on or tun them off and on several times a day for energy efficency?
This is an old urban legend.I know it takes a bunch of energy to "start" a flourecent light, is it better to leave them on or tun them off and on several times a day for energy efficency?
I agree. I have measured and recorded current waveforms for start up.Lets say a running fixture draws 1 amp continuously.
Now lets say it draws 10 times that during a 1 second start up. (I doubt it is anywhere near that)
So if we leave the lamp off for a 11 seconds or more we start saving more then the start up wastes.
Fewer than 10 cycles from turn on to steady state..
Turning off any lamp always saves the most energy because after all, it is not using any.
I wouldn't use the term "any". There are high bay lights that take a while to come on and are better left on during a work period.
This is OT but this thread just reminded me of desiel engines! Do you leave them idling or turn them off!:smile:
My thoughts are similar to Bob's.
There is a reason that someone has calculated for the setting of sensors to go off approximately 8-15 minutes.
FYI- Something I will share with you from experience, these sensors will burn through bulbs like crazy. That is why they are set to 8-15 minutes. One shop set their sensors to go off in 20 seconds and they replaced bulbs at 6 times the usual rate. The cost of the bulbs, rate of the electrician and his equipment all have to be calculated in the 'real world' cost savings, if there is any.
We have talked here about shorting lamp life with frequent start ups from sensors. I have seen sensors added to restrooms by energy management guys. Restrooms have 3, 13-watt fl. lamps.One lamp remains on always,(egress). So you are shutting the other 2-13 watts on/off all day!! The energy savings???? Does not outway the lamp replacement cost?? Oh, I mentioned the other 1200,2x4 trouffers that stay on most all the time! Energy guys did not "hear" that one!!:-?My thoughts are similar to Bob's.
FYI- Something I will share with you from experience, these sensors will burn through bulbs like crazy. That is why they are set to 8-15 minutes. One shop set their sensors to go off in 20 seconds and they replaced bulbs at 6 times the usual rate. The cost of the bulbs, rate of the electrician and his equipment all have to be calculated in the 'real world' cost savings, if there is any.![]()
