I am here in Afghanistan doing electrical work. I insist upon Code in all that we do. As I insist upon it, I insist upon other folks to adhere to trade rules and regs. Now, the other day and electrician and I were taking a panel cover off and one 3-ph breaker popped out and took out a phase. Then the adjacent breaker popped out and that circuit went down. The A/C unit went out but the A/C unit was not suppose to be on the circuit. So, why does that happen? Well, the previous workers on the electrical did not label their work. Plus, the breakers were not the right breakers for the box.
Also, there were live wires under the building that were left over from another job. No one took them out after the equipment was removed and then the breaker was turned on and no one knew the wire was under the floor boiling water when it rained. We knew there was a problem when there was about 7 amps on the ground ring. Well, no wonder! So, I insist upon code cert personnel and lic. At least at some point this person will have known something to be able to get a lic.
Soldiers getting electrocuted, abandoned power cables being hot, no proper ground/bonding, using the wrong armor wire cable, using no grounds,..just an overwhelming list of bad work. Plus, personnel think since they do electrical work at home they are now the experts in an environment that has never been code, so they put in something not understanding the overall power architecture in a facility. ALWAYS DEMAND THE RIGHT THING! CODE IS IMPORTANT! THERE IS NO SECOND CHANCE AFTER SOMEONE IS ELECTROCUTED BY STUPIDITY!
