LawnGuyLandSparky
With respect to the OP and as others have mentioned as long as the circuit is GFI protected you're OK. However IMHO if you don't locate the GFI protection outside and within sight of the tub you're doing a diservice to your customer. While you would be within the code guidelines, if the GFI happened to trip a person using the tub would have to get out of the tub (wet) and go inside to wherever the GFI is located to reset it. Just a personal preference of mine.:smile:
I would suggest that should the GFCI trip, the user should exit the tub and NOT reset it and get back in until the cause was found. So they're going back into the house anyway.
