Currently stationed in Africa. Local power where I am is 240V per phase, 400 phase to phase at 50Hz. I have been dealing with several loads made in, and for use within the U.S. Most of the electronics (TVs, computer) do not have issues.
However, others are having issues. Some of the loads, like a few clothes dryers, are 120/240, but would normally require 120 off of two legs and a neutral (3 wire). Currently, they are connected to the available single phase 240 (with nothing to the second hot leg input) ground and neutral. Ground and neutral are bounded at the main. The dryers are running for 30 seconds and cutting off. Shortly after, an audible click will sound allowing them to start back (over temp reset??). There are a few resistors on a circuit board in the back panel showing extreme amounts of overheating.
My main question here is how will a 120/240 load like this react to a single phase 240 supplied to one side. I am thinking the current will not behave the same. Also there's the freq, only 50Hz when the dryer calls for 60. Don?t think this is as much an issue. But what about frequency in other loads? High intensity lights or other various motors for example. Or are there any other loads I need to be specifically careful with. I understand the motors will run slower but overall affects or damage??
