I think I know the answer to this question, but I am looking for clarification. What code sections would apply to using an I-beam as a raceway, with a cover attached to the beam flanges? (Thus using the I-beam as a raceway) My best guess is that this is not a listed raceway. We need to refeed a few panels from overhead, and there is no room above and in front of the panels for cable tray (due to required separation distance from the telecom cable tray),and we need to allow for future panel refeeds. The only option we could find was to install a cable tray or square duct inside of the beam. This cable tray would need to be cut into short sections to install it between the existing conduits exiting the tops of the panels. The I-beam runs in a horizontal direction about 1' above panelboards and behind the panels. (The panels are bottom fed, mounted on a cored block wall with an I-beam sitting on top of the blocks. Please excuse my cheesy ASCII drawing! :smile: What would be the code issues with manufacturing our own custom raceway (cable tray) from sheet metal?
Thanks-
Bryan
~~Elevation drawing~~
][ .....UUUU <---- Fiber optic / network cable trays
][ <------------- I-Beam
||] <------------ Panelboards mounted on block wall
Thanks-
Bryan
