this is a bit of a complex situation I will try to be clear and brief
a huge portal type granular loading equipment for transferring granular material from pile to conveyer belt run on train type rails back and forth
power coes from a main junction box, via 2 power cables joined together in the box which then goes to 2 cable reels from where it goes to 2 motorised slip ring assemblies passes thruogh the moving contacts to the fixed contacts then joined together again at a main isolator and then enters to the control cabin in the operators station on the mobile equipment, 2 power cables are used,if one is damaged it can be disconnected and the loader ran on one cable
now heres the thing,as the two cables are joined in the main isolator on the loader current will feed back to the slip rings that has the disconnected power cable on the fixed contacts!
if someone e.g. a shift worker not totally familiar with the system ,or someone forgets the arrangement,if any work is to be done on the disconnected slip ring assembly ,gearbox or reel,and they need to get in the slip ring box,assuming the power cable is disconnected and safe,he might get shocked or worse
I recently attended electrical safety training from N.T.T inc. and I suggested to my superior that we should put warning signs to the effect, or install separate isolators on the loader for each cable, he thought the idea unneccessary was not interested
Don't electrical injuries happen in the unguarded moment? should we not be more carefl than less careful?
Are there any electrical codes or rule that can apply?
