Minuteman
- The Sooner Nation
I was called to replace some outlets for a new counter top back splash in a Church kitchen. Panel is a QO, 240v delta, located in the kitchen. The only label was for the 3 pole A/C and the 2 pole WH.
Using my circuit tracer, I plugged into the top of the first duplex and found the circuit to be #24. As I removed the 15a duplex, I saw that there was 2 blue conductors on the hot side and only 1 white on the neutral side. About that time I touched the lower hot screw with my index finger, while I had my left hand on the stainless steel sink.
Turns out, that the breakout tab was removed from the hot side, and that #12 was connected to it. (Both on C phase). Come to find out, all 3 duplexes on that counter were that way. The first was #12/24, the second was #8/14, and the third was #13/20. :-?
I have since cutaway enough of the Formica to remove the single gang plaster rings and replased them with two gang. After the new back splash is installed, I will install two 20a GFCI outlets in each box. I have moved around the conductors so that they will be now be grouped as #8/12, #14/18, and # 20/24.
