wireman1
this question may have come up before but it came up in a discussion with some of the electricans i work with.is it a code violation if a existing panel down stream which is a sub panel and happens to have a 400 amp main be protected by a 200 amp breaker located in a service panel in the electrical rm? because a lot of the loads will be elimated. isee no problem with this as long as the wire to the 200 amp breaker is the proper size
