PVC coming out of slab crooked
So, my father-in-law decided to build a detached garage. He figured he wouldn't put in electric for some time so he put a 1-1/4" sleeve through the slab. Now he wants electric and there's one problem. He installed the sleeve (90 deg, 1-1/4") so close to the edge its pressed up against the garage wall. It's only stubed out about 3". Anyone have some tricks up their sleeve on how I can get a coupling on this thing in order to extend to a subpanel? Sorry no pictures, didn't have the camera with me.
1. notch the wall
2. use heatgun on pvc to bend off the wall
3. don't use it
ive done this before in this situation:
things you need -coupling, glue, swazall, scrap of 2x4, hammer
-take a swazall and bevel the edge of the pipe to slant down a little towards the wall
-liberally coat half of the coupling and the pipe with glue. use alot of glue so it doesnt start to set up right when the coupling touches the pipe.
-set coupling on top of pipe
-set 2x4 on edge centered across coupling
-wack the 2x4 with the hammer to seat the coupling on the pipe.
You should be able to use a heat gun to warm the PVC enough at the concrete line to be able to bend it away from the wall enough to get a coupling on it. Then heat the new conduit enough to finish your offset for a plumb piece of conduit.
Can't picture it from your discription, but sounds like you need to chip down around the PVC enough to then use a heat gun to soften the pipe to bring it up straight--you will no doubt lose some internal wire space--but pull the wire from this end and you'll only strain the last six feet!:grin:
