I am doing a rewire on a existing house and changing the 100 amp meter base and panel to a 200 amp meter base and panel. I have a meter base with a 200 amp main breaker located inside of meter housing and need to run 50' of 2/0 copper ser or seu service entrance cable to feed the new 200 amp panel. Is this ok to run? I will be coming straight up from meter base with conduit into attic and installing the se cable in a unfinished attic area. The condit is only a 20" section.
