Sam Branch
I need help to settle a disagreement. Under the NEC can you use white plumbing PVC in leu of gray listed PVC?
listed PVC
I would never pass it :grin:I need help to settle a disagreement. Under the NEC can you use white plumbing PVC in leu of gray listed PVC?
When it comes to the larger sizes, plumbers stuff gets into being cellular core material.
It must be a local thing as you will not find that here, I recently ran some 4" PVC plumbing pipe and it was solid walled.
Both are made, but usually once the plumbers get into 1?" and larger (for vents and drains only: no pressure), it's cell core.
Some PVC electrical conduits are white. Type A for example.
Here in MA cast iron is still required for non-dwelling units so it would not surprise me that MA would not allow cell core at all.
Does that mean you are not really an electrician? :grin:Not that I ever use a torch to bend pvc :grin:
That's interesting.but anyway, once when I 'wasn't" bending some that way, I also tried to bend a white one for the ac contractor's drain pipe for him so he could saddle a water pipe. I found the white stuff doesn't bend near as well as the gray when a heat source is added, it will kink much easier.
