ultramegabob
- Indiana
I believe if you have a normally closed set of contacts, the A/C should work as normal, but when the transfer switch engauges, you will open that ciruit and not allow the thermostat to turn the conderser on. Maybe there is someone who specializes in HVAC on here that can give some input....
Edit- nevermind, I keep thinking you are using a whole house transfer switch and not a seperate panel....
