I also measured current on the other egc's. not as high but close. What is FOP and thanks for the quick response.
FOP means fall-of-potential. In theory, you should measure almost zero volts between two points along a conductive pathway; say, from the meter terminals to the bus in a panel.
If you measure, for example, 0.07v on A, 0.09v on B, and 1.8v on C, you'd know you have a poor contact between two points somewhere along C phase, and there should be a bit of heat there.
Normally, you measure between two adjacent points, such as service wire to meter line terminal, line terminal to load terminal, load terminal to load wire, load wire to bus terminal, bus terminal to breaker load terminal, etc.
Where/how would you measure the voltage? I'm not sure what voltage to measure.
See above. It's much easier to find a small voltage drop between two points than it is to pinpoint a similar drop in voltage along a series of points.
This is an example of a voltmeter being the better tool for the job than a solenoid-type tester. Make sure you start with a high voltage setting, just in case.
