- Massachusetts
I believe it is. The valves are designed to block flow from a higher pressure to a lower pressure. The valve has no idea if the pressure differential is caused by introducing pressure on the inlet side or vacuum on the discharge side. Same same as far as the valve is concerned.:smile:
I hear what your saying it makes lot of sense except that I believe they also have passages to atmospheric pressure and the spring(s) would be calibrated with an expectation of a pressure higher than atmospheric pressure not lower.
But I will gladly admit I am not sure. :smile:
