Maybe he isn't in the US?You might want to re-check the voltages you posted, there is no 280 volt or 110/240 volt US system.
Welcome to the forum. :smile:
I have a big three phase plasma cutter that has variable amperage, no problem. My problem is It specifically calls for 280/480 and all I have is a 110/240 panel. What would you guys do to make this work? thanks, Mark.
A DC link choke plus capacitors might be a better idea.To smooth out the DC ripple, you could add a motor's run capacitor to the DC circuit.
I'm sure you are right - it was a tongue-in-cheek comment about your assumption. No offence intended - my sweet wife is from Georgia so I have some familiarity with the similarities and differences.I'll take my chances with the assumption that he mistyped the voltages.![]()
This unit can be hooked up to variety of voltages, and at 240 it will require 53 amps, but it is a 3 phase unit, so if you have a 3-phase panel then your good to go, just wire it for 240 volts delta, if you have a 120/208 Y then that is what you wire it for, the amount of current will depend upon the voltage, but this machine will wire to almost all US electrical systems with out a problem, as long as you have 3-phase supply, or a roto-phase converter.
It is the output to the cutting head that is 280 volts DC OCV @ 100 amps max.
I read the voltage chart as being Model # dependent, not as being universal.
