Ok, so I have #6awg= 2 hots, neutral and a ground running from main panel to heater disconnect. Then, from the disconnect to Heater.
I have a 240v GFCI breaker to install but:
1) The heater only has terminals for 2 hots and a ground. What do I do?
2) Just to be clear, this heater says 208/230v PH 1 60hz. Can I hook this up in a residential setting(meaning can i hook up 240v to this thing without ruining it?
3) what is available for bonding the pool frame? There is no lug on it anywhere? It's an above ground pool.
