thank you!!
ungrounded conductors high or low voltage #6 or smaller:smile:
thank you!!
im not sure cant find it but ill look at those
thx:smile:
200.6 Means of Identifying Grounded Conductors.
(A) Sizes 6 AWG or Smaller. An insulated grounded conductor of 6 AWG or smaller shall be identified by a continuous white or gray outer finish or by three continuous white stripes on other than green insulation along its entire length. Wires that have their outer covering finished to show a white or gray color but have colored tracer threads in the braid identifying the source of manufacture shall be considered as meeting the provisions of this section. Insulated grounded conductors shall also be permitted to be identified as follows:
(1) The grounded conductor of a mineral-insulated, metal-sheathed cable shall be identified at the time of installation by distinctive marking at its terminations.
(2) A single-conductor, sunlight-resistant, outdoor-rated cable used as a grounded conductor in photovoltaic power systems as permitted by 690.31 shall be identified at the time of installation by distinctive white marking at all terminations.
(3) Fixture wire shall comply with the requirements for grounded conductor identification as specified in 402.8.
(4) For aerial cable, the identification shall be as above, or by means of a ridge located on the exterior of the cable so as to identify it.
250.119 Identification of Equipment Grounding Conductors.
Unless required elsewhere in this Code, equipment grounding conductors shall be permitted to be bare, covered, or insulated. Individually covered or insulated equipment grounding conductors shall have a continuous outer finish that is either green or green with one or more yellow stripes except as permitted in this section. Conductors with insulation or individual covering that is green, green with one or more yellow stripes, or otherwise identified as permitted by this section shall not be used for ungrounded or grounded circuit conductors.
thx:smile:
thx raider1 thats what i thought but i failed and he was using nec
not sure if i want to question him maybe making him madder it is a short run
but i think he is wrong
Chris we are on the same page. sorry you post a lot faster than me there Wyatt Earp..:smile:
Yep, I'm the fastest two finger typer in the west.
Chris
thank you!!
What was the original color before you re-identified it?
Mic.....Can't find what? Your code book.
That is a good point Rob.
Chris
You use two fingers? You mean one on each hand? Wow!Yep, I'm the fastest two finger typer in the west.![]()
