Buck Parrish
- NC & IN
I'm doin the finish on a pretty upscale home. The master bed fireplace is all walnut. The carpenters needed some cut in boxes to make holes for the sconces on the fireplace. They didn't want to cut around boxes fastened to the fire place structure, so we used cut ins. Problem is I gave them those stupid blue round cut ins from home depot which apparently are 4" and of course the sconces don't cover a 4" hole. Expensive mistake. I guess I should have used a 3" pan or something, but I don't think you can legally put 1 14-2 in them without going over box fill.
Does anyone have any ideas how to fix it with out redoing the whole fireplace? I am thinking custom adaptor or something.
What do you do in a similiar situation?
Use a 5" hole saw cut a hole in a piece of sheet metal. Paint the 5" part to match the sconse. You may need to sand the edges a bit. And of course a hole to pull your wires through.
You will only see a about a half inch of it.
Other wise you could offer to install the two sconse some where else. And they get bigger ones for the fire place.
