I use the Carlon Cable Dispenser WK7203 for MC and pull it from the center when using 250' coils.
Only about $50.00
Only about $50.00
We buy 1000' spools that are 'reverse wound' they makes it pull much better through studs or over steel truss.
I sometimes save old reels and have 'chuckle-head' re-roll them with my home-made crank set-up. Sometimes the chuckle-head will vary. :grin: Takes a few minutes - depending on which chuckle-head is available.
Only about $50.00
Will the stud mount hang on steel studs? If not I guess I could screw a dummy wood block to one.
So, pop these into the holes:
There is not a clean cut hole. The punch basically just rips the stud open.
Sounds like it's only good if you're running EMT.
Sounds like you need to read the thread. :smile:
There was a manufacture that made square MC or maybe it was AC cable years back, I don't know if it's still manufactured, but was supposed to be easier to pull thru studs.:smile:
Back in my younger days I took a piece of mc and shaped it into an 'E', then I hammered
it square ( took about two hours ) then hung it on the wall. People would say " what's
that ", I told them, E=MC squared !!
Yeah, I know, thanks for sharing.
