TOOL_5150
- bay area, ca
Im not used to this type of setup, so let me explain what I got. 1 property has 2 houses on the lot, OH drop to 2 seperate meters, feed from 1 of the meters goes OH to the second house [about 20 feet]
Each meter goes to a panel, that have 100A mains in them, though the 2nd houses meter has the main @ the meter - not @ the house.
I am replacing both meters, and both loadcenters, I was thinking on getting a 2 meter pack, with 2 100A breakers in them. The first house where the service enters has a plastic water main, the second has a metal main. DO I put a ground rod @ each house, and then to the water bond? What about the house with the plastic watermain? Just to verify also - if the main for the second house is @ the enterance [first house] I need 4 wires to the second house, correct? I am used to single family dewllings, so this one kind of threw me for a loop.
~Matt
~Matt
