Paper on the case for MV Data Centers
mull982,
You might be referring to the attached document.
Our VP had me run SKM to check his IEEE 1584 calculations for a comparison between similar 480 and 4160 Volt systems, and credited me as a co-author.
The reason why the MV systems have less Incident Energy (IE) is that the arcing fault current for the MV systems is very close to the short-circuit current so it lets the trip mechanism operate in it's fastest region. Low Voltage arcing faults, on the other hand, are one the order of 1/2 of the value of the short-circuit current, so there's a significant delay that allows for the buildup of IE, often to the 2 second default value.
John M
