I have a 30 amp 3 pole 3 position switch which is going to feed some equipment at a police station. Just 2 circuits, one pole is not used.
One side is normal power the other is to a generator which has to be started by hand and the common poles go to outlets to feed equipment.
My question is can the neutrals from normal power and generator power land on the same block. I thought I should switch the neutrals. If I don't will this cause any problems? Because power will come back on while the generator is supply power to equipment. And then the neutrals then become common to each other. Before they reconnect to normal power. And turn off generator.
We have alot of power outages here and they have been starting the generator and plugging ex. cords to equipment.
Thanks in advance for any input.
