erickench
- Brooklyn, NY
There is an EGC i.e. ground wire, metal conduit, etc. for the the AC system. It's just not connected to a grounding electrode. The DC current comes from the tracks and goes through the earth. That's why they have negative equalizers for every signal block in the system. It equalizes the voltage between the negative running rails and reduces the corrosion. The negative running rails are bonded to the structural metal of the system.
