T&B? BlueKote? Universal Conduit Elbow
Our salesman brought around a sample unit in 1/2" size. If you need to do a 90 degree change in direction like an LB, LL, or LR it would work fine as long as you're not tight on space. It doesn't really replace a C fitting because the two conduit entries are 90 degrees from each other, not parallel like in a C. I think somebody ordered a couple in 3/4", 1", and 1-1/2" to try when the opportunity comes up - I haven't seen them installed yet though.
an elongated pulling 90. not a bad idea. if you can pull through it like it claims, thats a great idea (I hate pulling L's, but when you gotta use em it beats the alternative)
