I understand that is is acceptable to install a main FACP to host and control slave panels in a multi-occupancy building or in a multi-building complex, but it is my understanding that these systems, though they report to one main FACP, must be autonomous in nature so that they are NOT dependent on a single panel to get their signals out. As a rule of thumb, my general practice is to assess the buildings in such a way that if the building has its own fire riser, then it should have an autonomous FACP. I have worked on networked systems before, but am getting some resistance from a valued customer who thinks it is acceptable to have ONE FACP control FOUR separate buildings that are not connected to each other. Each building currently has expansion modules hooked up on the main FACP bus line and the system is partitioned so that if one building goes into alarm, the others stay in whatever state they are in. I think this is a code violation, but because I don't have my copy of the NFPA 72 sitting right in front of me, I can not definitively tell them this is the case. Is this a code violation?
thanks
Josh Kopczynski
DPI Security Solutions
thanks
Josh Kopczynski
