Charlie Bob
- West Tennessee
got my fluke 1587 advance troubleshooting kid this week.
I'm gonna start getting used to this testings, but tell me if im correct, please.
1--If i'm to meeger a circuit with 5 receptacles, for instance, I disconnect the load side from breakers,(Everything that is plugged in, and disconnect hot wire from breaker, white from neutral bar, and groun from ground bar.)
Then can i run the test with the five recep.in the circuit, or should i disconnect circuits ?
2--If i disconnect recep. can i wire nut wire together and then test.
3--If the insulation test measures resistand along the insulation, showing weak points where insulation is damage or non existant, how does the terminals on the recptacles affect the test?
4--What can i do to start getting used to it?
Plase i appreciate any ideas>
