Years ago when replacing some switchboard meters the guy I was working with had some clips you could use to short out the CT's if there was not a shorting block installed.
They looked kind of like test leads only the spring loaded ends would actually pierce the insulation of the CT leads. Made a very small cut/piercing. You clipped one end to the + lead and one to the - or common if it was a wye and shorted the CT out so you could replace the meter or install permanent shorting blocks.
I need a set of these clips but cannot find them anywhere.
Anyone know what I'm talking about and know where to get them or even what they are called?
