I have 6 - 20amp circuits I can work with. These are already in use and we are concidering revamping our production layout. I have 3 belt sanders that pull 5.3 amps each that are 208 - 3ph.; 6 bench grinders that pull 4 amps each that are 110; and one torit that pulls 12 amps that is 208 - 3ph...
A compliant application here will require a great amount of time and energy to qualify correctness. You cannot do this without NEC. A glance at minimum (these listed motors only) for your panel and feed size should include the following:
Motor------HP-----PH-----V-----Table A---Name Plate
Belt 1-----1.5 ?----3-----208-----6.6--------5.3
Belt 2-----1.5 ?----3-----208-----6.6--------5.3
Belt 3-----1.5 ?----3-----208-----6.6--------5.3
Bench 1---3/4 ?----1-----110-----6.4--------4
Bench 2---3/4 ?----1-----110-----6.4--------4
Bench 3---3/4 ?----1-----110-----6.4--------4
Bench 4---3/4 ?----1-----110-----6.4--------4
Bench 5---3/4 ?----1-----110-----6.4--------4
Bench 6---3/4 ?----1-----110-----6.4--------4
Torit-------5 ?-----3-----208-----16.7-------12
Panel & Feeder 430.62
Torit (Table Amp x 2.50)--250.0%--41.75
Belts (Table Amp)------------------19.8
Benchs (Table Amp)----------------38.4
Total Amp-------------------------99.95
Min OCPD-------------------------100
Min Conductor-------310.15
