Jacob.Ball
- Cool California 95614
I have had many questions recently regarding the AC side of PV Installations. My question is, if you run L1, L2, and a ground from your sub panel to an inverter, do you need a neutral? If so where does it state this in the code?
Most Inverters come with the ability to wire them without a neutral.
I also know that most AHJ's will fail an installation if the neutral is not present.
