Panel is full - can I add a subpanel
mmiller
I have a 480 panel at work. Its a 800amp main. The connected load is probably right around 25% of that. I have run out of breaker locations on this particular panel. What are my options ?
1. Can I remove a breaker and replace it with a larger one to feed a sub-panel?
2. Could I install larger breaker and run a couple of fused disconnects from it for my extra loads ?
3. Listen to what the professionals have to say ?
I like #3 the best
Yes you can.
Yes you can.
I like #3 the best
Well, the depends on the professional(s) you have answering your questions. ;)
Roger
I like #3 the best
Depending on the budget I would add a load center. Sized appropriately. Take into account current load and future loads. Take into account if the system is series rated or not for fault current . Purchase appropriate fault rated
equipment.
Do you have pictures. Those are always nice to have?
